[GRASS-dev] Re: [GRASS GIS] #73: r.out.gdal tiff output does not
work
trac at osgeo.org
Fri Feb 29 21:33:13 EST 2008
#73: r.out.gdal tiff output does not work
Reporter: helena | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: default | Version: svn-trunk
Resolution: | Keywords: r.out.gdal, tiff
Comment (by helena):
Eric mentioned several viewers that don't like the tiff produced by
r.out.gdal and for me it won't work with Preview on Mac and gimp. You can
try for yourself:
here is an original tiff file that is readable by gimp and preview and
imports
to GRASS nc_spm_07 LOCATION using r.in.gdal (change tfwmf to tfw).
http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/ncexternal/IMG3720079200P20040216.tfwmf
http://skagit.meas.ncsu.edu/~helena/grasswork/grassbookdat07/ncexternal/IMG3720079200P20040216.tif
After exporting with r.out.gdal the image is not readable. But you are
right that the numbers appear to be correct but there seem to be some out
of range values (nulls?). With some other rasters where I had nulls I
tried to define nulls as -9999 and export to AAGrid using r.out.gdal but
there was a problem too.
Here is one example of exported tiff
http://skagit.meas.ncsu.edu/~helena/grasswork/ortho_2001_t792_1m.tif
http://skagit.meas.ncsu.edu/~helena/grasswork/ortho_2001_t792_1m.tfw
there may be some option that exports the tiffs correctly but the only one
that was readable was this
http://skagit.meas.ncsu.edu/~helena/grasswork/lakes.tif
http://skagit.meas.ncsu.edu/~helena/grasswork/lakes.tfw
Thanks for looking into it
Helena
Ticket URL: <http://trac.osgeo.org/grass/ticket/73#comment:5>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
