[GRASS-dev] Re: grass-dev Digest, Vol 21, Issue 1
Michael Barton
michael.barton at asu.edu
Tue Jan 1 11:15:03 EST 2008
On Jan 1, 2008, at 3:13 AM, grass-dev-request at lists.osgeo.org wrote:
>> #12: gis.m->Help->About system doesn't work (launches another
>> gis.m instance)
>> Reporter: neteler | Owner: grass-dev at lists.osgeo.org
>> Type: defect | Status: new
>> Priority: major | Milestone: 6.3.0
>> Component: default | Version: unspecified
>> Resolution: | Keywords:
>> Comment (by cmbarton):
>> Replying to [ticket:12 neteler]:
>>> Clicking on 'About System' within the gis.m Help menu launches a
>>> new set
>> of gis.m windows instead of opening a tcl/tk window with system
>> parameters. The newly created gis manager toolbar says "Tk System
>> Information".
>>> PS: moved here from
>> http://wald.intevation.org/tracker/?
>> func=detail&atid=204&aid=553&group_id=21
>> Is this function worth the trouble of trying to fix?
> This is just a symptom of a larger problem, namely that the Gm::errmsg
> procedure is defined in gm.tcl, which cannot be "source"d (because
> doing so will "run" gis.m).
> Gm::errmsg belongs in a "library", i.e. a Tcl source file which can be
> "source"d from other Tcl source files.
> Also: gm.tcl calls Gm::errmsg from top-level code at the beginning of
> the file (the code which copies various g.gisenv settings into $env),
> although the procedure isn't actually defined until much later in the
> file. If any of those "catch" statements actually catch an error, the
> handler will throw an error due to Gm::errmsg being undefined.
Making a library and moving Gm::errmsg to it is pretty easy to fix
(just a LOT of find/replace throughout the GUI code). Anything else
that you know of should come out of gm.tcl and into such a library?
However, making the 'get system info' function work is more trouble.
As I said in the rest of the post, it's very old code. Is it worth
bothering with to have the GUI launch a window with a bit of minimal
system info?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080101/34db5a2f/attachment.html
