[GRASS-dev] Re: [GRASS-trac] #7: Location wizard: should predefine
DB connection for new location
GRASS-trac
trac at osgeo.org
Tue Jan 1 14:52:20 EST 2008
#7: Location wizard: should predefine DB connection for new location
Reporter: neteler | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: svn-trunk
Resolution: | Keywords:
Changes (by neteler):
* component: Python => default
* milestone: 6.4.0 => 6.3.0
Comment:
I disagree and think that new locations should be valid locations - or -
*all* modules should be able to work with locations lacking the VAR file.
I see no point in having this trivial thing lacking and then make the user
stumble about several commands not functioning.
The "file system noise" is in average 70 bytes (!) per MAPSET which can be
just ignored as a problem.
If we have a default DBMI driver (which is yet DBF), we also have to set
default settings. No complaints in 6.2 probably because use cases are
different.
Scripts like v.db.add* cannot run that automatically because we don't want
to hardcode DBF (or whatever driver) many times scattered all over the
source code but only in a single place (which was the init script and I
still complain that this was removed leading to broken DBMI settings - see
the archive for this).
Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/7#comment:5>
GRASS-trac <http://grass.osgeo.org>
Commonly referred to as GRASS, this is a Geographic Information System (GIS) used for geospatial data management and analysis, image processing, graphics/maps production, spatial modeling, and visualization. GRASS is currently used in academic and commercial settings around the world, as well as by many governmental agencies and environmental consulting companies.
