[GRASS-dev] d.legend uses a static buffer for `map='
Mon Jan 7 06:39:43 EST 2008
Ivan Shmakov wrote:
> 	As of a recent SVN HEAD, `d.legend' uses a static buffer to
> 	store the value of the `map' option.  It's therefore impossible
> 	to pass raster names more than 63 bytes long to `d.legend'.
> 	Since I don't see why a static buffer may be necessary here, I
> 	suggest the following (yet untested) patch.
> diff --git a/display/d.legend/main.c b/display/d.legend/main.c
> index d827d04..324012d 100644
> --- a/display/d.legend/main.c
> +++ b/display/d.legend/main.c
> @@ -39,7 +39,7 @@ int main( int argc, char **argv )
>  	char *mapset ;
>  	char buff[512];
> -	char map_name[64] ;
> +	const char *map_name;
>  	char window_name[64] ;
>  	int black ;
>  	int cats_num ;
> @@ -188,7 +188,7 @@ int main( int argc, char **argv )
>  	if (G_parser(argc, argv))
>  		exit(EXIT_FAILURE);
> -	strcpy(map_name, opt1->answer) ;
> +	map_name = opt1->answer;
>          hide_catstr = hidestr->answer;  /* note hide_catstr gets changed and re-read below */
>          hide_catnum = hidenum->answer;
> PS.  I've seen a number of other uses of static buffers scattered across
> 	the code, leading to both potential limits and crashes, which
> 	I'm on the way to investigate.
There isn't necessarily a problem with using fixed-size buffers for
map names, but the size should be GNAME_MAX. Similar constants exist
for mapset names and pathnames:
	/* File/directory name lengths */
	#define GNAME_MAX 256
	#define GMAPSET_MAX 256
	#define GPATH_MAX 4096
In the specific case of d.legend, your fix is the correct one, except
that map_name needs to be "char *" not "const char *", as
G_find_cell() may modify the map name (it removes any @mapset suffix).
As this never enlarges the string, it's okay to re-use the original
buffer.
