[GRASS-dev] [grass-doc I][574] v.in.ogr
grass-dev at lists.osgeo.org grass-dev at lists.osgeo.org
Mon Jan 7 13:49:28 EST 2008
doc I item #574, was opened at 2008-01-07 18:49
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: v.in.ogr
Issue status: None
Doc section: vector
GRASS version: CVS HEAD
Doc timestamp (YYMMDD):
Initial Comment:
In v.in.ogr (in the gui), in the "output name" field [Name for output vector map:], in the descriptive text in the parenthesis it sais:
"(output: name, optional)"
Should the optional be "required"?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=574&group_id=21
