[GRASS-dev] [grass-doc I][574] v.in.ogr
Paul Kelly
paul-grass at stjohnspoint.co.uk
Mon Jan 7 14:10:25 EST 2008
On Mon, 7 Jan 2008, Patton, Eric wrote:
> Fixed in svn trunk; I'll apply it to the 63release branch soon.
> ~ Eric.
> -----Original Message-----
> From: grass-dev-bounces at lists.osgeo.org on behalf of grass-dev at lists.osgeo.org
> Sent: Mon 1/7/2008 2:49 PM
> To: noreply at wald.intevation.org
> Subject: [GRASS-dev] [grass-doc I][574] v.in.ogr
> doc I item #574, was opened at 2008-01-07 18:49
> Status: Open
> Priority: 3
> Submitted By: Nikos Alexandris (nikosa)
> Assigned to: Nobody (None)
> Summary: v.in.ogr
> Issue status: None
> Doc section: vector
> GRASS version: CVS HEAD
> Doc timestamp (YYMMDD):
> Initial Comment:
> In v.in.ogr (in the gui), in the "output name" field [Name for output vector map:], in the descriptive text in the parenthesis it sais:
> "(output: name, optional)"
> Should the optional be "required"?
IIRC it is optional because you might want to just list the available
layers in the input OGR source (-l flag), in which case you don't need to
specify an output map.
Paul
