[GRASS-dev] [grass-doc I][576] r.bitpattern -- add a table and
examples for it?
grass-dev at lists.osgeo.org
Fri Jan 11 00:17:28 EST 2008
doc I item #576, was opened at 2008-01-11 05:17
Status: Open
Priority: 3
Submitted By: Nikos Alexandris (nikosa)
Assigned to: Nobody (None)
Summary: r.bitpattern -- add a table and examples for it?
Issue status: None
Doc section: raster
GRASS version: CVS HEAD
Doc timestamp (YYMMDD):
Initial Comment:
It took me a while till I really understand how to use the MODIS Data Quality Band (Quality flags, in my case for MOD09 products). Finally... I got it after (re-)reading the description (in a post) of Glynn Clemments... (using actually r.mapcalc).
In my honest opinion, I think that the example(s) for r.bitpattern are not clear enough for beginners like me.
I am creating a table (maybe to be help to understand better how it works to get the correct values for "position (pattern)" and "pattern value").
Should I send it as a doc "issue"?
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=576&group_id=21
