[GRASS-dev] table only creation in v.in.ascii
Moritz Lennert
mlennert at club.worldonline.be
Fri Jan 11 04:23:46 EST 2008
On 11/01/08 09:51, Benjamin Ducke wrote:
> Yes, it was meant for svn-trunk.
> I just re-generated it and it works without fuzz on
> my fresh SVN checkout (09:45 am CET).
> Try the attached version if you like.
> I will put work on this feature on hold until there is some
> clarification whether these changes are actually wanted ...
> However, I'd like to add the ability to read field names
> from the ascii input file to v.in.ascii.
> Should I add a flag to interpret the first line as
> field labels?
> Does anyone know what the restrictions on DBF field
> names are? Length?
8 chars
> Special characters?
You should probably avoid anything non-ascii.
Moritz
