[GRASS-dev] d.legend uses a static buffer for `map='
Ivan Shmakov
ivan at theory.asu.ru
Sat Jan 12 04:52:05 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
> More generally, anything matching:
> grep '\[[0-9][0-9][0-9]*\]'
> deserves at least a cursory glance. Many of those should really be
> using a #define'd constant, even if it's local to a single source
> file.
Could you review the attached patch?
Things I didn't change with this patch:
* buffers related to SQL commands, because I know no appropriate
Cpp macro for these;
* buffers related to command lines to be passed to system (),
since I believe that using a specific library to construct the
arguments lists to be passed to an `exec' family function
directly would be a better solution; (check the `man-db'
source [1] for a suitable facility);
* misused G_warning (), etc.; like:
char BUF[...];
sprintf (BUF, FORMAT, ...);
G_warning (BUF);
instead of:
G_warning (FORMAT, ...);
(the documentation should emphasize the first argument being
the printf ()-style format string, and /not/ the message);
there're just too many of these and I hope to handle them with
a script;
* use of gets ()-like functions to discard everything on stdin
until the next newline; a separate function is needed there;
* all the other things I've missed or had no time to look at
(nviz/ and most of ps.map/ in particular.)
[1] http://www.chiark.greenend.org.uk/%7Ecjwatson/bzr/man-db/trunk/
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080112/b58d77bd/buffers.patch-0001.obj
