[GRASS-dev] what if: Anything series?
Markus Neteler
neteler at osgeo.org
Sat Jan 12 15:07:53 EST 2008
Hi Ivan,
thanks for you impressive suggestions! I have right now added a tiny
contribution from Soeren Gebbert with a few bugfixes from me into
GRASS Addons-SVN:
r.rast4d + tg.* - raster time series SQL support
This is a scripted approach to register time series of raster maps
into a SQLite database. Comes in handy when dealing with thousands
of MODIS maps for example.
Markus
On Jan 11, 2008 9:02 PM, Ivan Shmakov <ivan at theory.asu.ru> wrote:
> It seems impossible to doubt that everything in
> the universe can be represented by numbers [...]
> -- N. I. Lobachevsky
> Reading ``Time series in GRASS'' page [1], as well as [2, 3],
> made me wonder, is time the only parameter one may need to lay
> the data sets along of? Arguably, it's not.
> Consider, for example, one having to compare the behaviour of
> MM5 modelling results with different models or parameters used.
> There, related rasters are laid along the model index or model
> parameter's value.
> Another example are the rasters comprising of the values of a
> meterological variable for certain (often non-uniformly spaced)
> values of pressure. These sets of raster data sets shouldn't be
> turned into 3D rasters, since the pressure to height
> correspondence varies over space and time.
> The above makes me believe that the generic facility to keep the
> relations between the rasters is necessary. Besides,
> implementing this facility allows for several other problems to
> be addressed within its framework, as I'd try to show below.
> * Several related rasters: a rasterset?
> Both of the examples above suggested using numeric values to
> represent the relationship between the rasters. These values
> can include:
> * timestamp (in seconds since epoch), allowing for time series
> [1];
> * layer's pressure;
> * model index or model parameter;
> * were quality flags applied to the raster (1) or not (0)?
> Let me define rasterset as a named collection of related
> rasters, each unambiguously identified by an arbitrary number of
> the arbitrary numeric values.
> Below, I assume using 2D rasters at the lower level of the
> rasterset implementation, since 3D rasters could easily be
> simulated by a rasterset with a `z' as the parameter.
> * Tiled raster storage
> The most simple case of using the rasterset facility is to
> implement tiled raster storage [3].
> Indeed, a tiled raster could be implemented with each tile
> becoming a raster within a single rasterset, and then being
> assigned a pair of numeric parameters -- the indices of the
> tile.
> Since the spatial resolution of the tile may differ (the rasters
> comprising the dataset are almost as independent as the
> individual rasters in GRASS currently), this allows for both the
> whole-NULL tiles (no raster for this tile indices), and for the
> same-value tiles (1x1 raster covering the whole region.)
> For the usage of this feature is supposed to be quite common, I
> believe it needs to be implemented at the ``core'' of the
> rasterset implementation, with the appropriate optimizations
> applied for some common cases.
> * Metadata
> Since the rasters comprising the rasterset are allowed to carry
> an arbitrary number of additional numeric parameters, this
> facility could assume handling of certain (though not arbitrary)
> metadata, even in cases where these additional parameters aren't
> strictly necessary for the identification purposes.
> However, with each raster being assigned a category, it's
> possible to associate arbitrary information with it using a
> database connected to the rasterset.
> * Color maps
> Color maps are currently tied rather closely to the rasters they
> are used for, making it hardly practical to use different color
> maps for the same rasters. This feature could be used, for
> example, to apply different color maps when displaying the data
> and producing the printed output.
> Would the color maps be detached from the rasters, it may become
> feasible to allow for a color map to be shared among several
> rasters.
> I've already mentioned a raster's parameter as a possible
> substitute for `z' (both for simulating `z' for ordinary 3D
> rasters, and for storing layers of data for which layer index to
> `z' mapping varies over space and time.) Moreover, for digital
> elevation models `z' value is actually the value stored in
> raster. It may be worth investigated whether this relation
> could be turned inside out, to allow for arbitrary value to
> arbitrary value mappings be stored as 2D (or 1D) rasters within
> a rasterset.
> There may be demand for storing quite arbitrary arrays in the
> future as well.
> * Scanning radiometers & Time
> Due to the curvature of the Earth surface, a satellite scanning
> radiometer such as MODIS sees certain places on Earth multiple
> times in a short period of time (about 1.48 s for MODIS.)
> These places appear on consequent scans on L2 data. The most
> common practices to deal with this effect are either to average
> the values obtained for the same place, or to take the one value
> that is, after some criterion, superior to the other.
> However, allowing for the scans to be stored independently along
> with a ``time'' value associated with each would allow one to
> analyze these very short-term changes (if any.)
> * RDBMS as the backend
> Probably the most appealing feature of the rasterset model is
> its supposed flexibility. As mentioned above, the color maps
> could be represented as the rasters in their very own coordinate
> space, and so could be the ground control points (*).
> With the number of separate data structures to form a raster
> reduced, it could become feasible to put these structures into a
> general purpose RDBMS system, thus partially addressing both the
> disk space and the large number of files in a directory concerns
> [4].
> (*) It's very common for the satellite Level 2 data to specify
> the latitudes and longitudes for the centres of the pixels as
> the separate rasters. These could be mapped directly to the
> specific rasters within the rasterset. See [5] for a related
> feature in GDAL.
> * Views
> The names aren't convenient for rasters. For example, I have a
> location full of rasters with the names like:
> 2007-05-31-grans-std-qual-o3
> 2007-05-31-grans-std-toto3std
> 2007-05-31-grans-std-toto3std.qa
> 2007-05-31-grans-std-toto3stderr
> The total number of the 2D data sets for each day is over 70,
> most of which come in both the ``no quality flags applied'' form
> (without the `.qa' suffix) and the ``standard quality flags
> applied'' one (with one.) And the source data do include even
> more data sets.
> In order to handle this amount of data efficiently the system
> should allow one to limit the namespace to the data sets
> matching arbitrary criterions. I don't consider the GUI
> specifically, since it may become rather tedious to filter the
> g.mlist(1) output with grep(1) in scripts as well.
> The rasterset model seems to be a more appropriate solution.
> And, as suggested in the next section, there could be a way to
> name a specific raster within the rasterset. With this
> functionality available from scripts, one could easily apply
> arbitrary schemes for naming the data sets.
> * User interface
> With the rastersets being implemented, GRASS database becomes to
> look much more like a relational one. Since the individual
> rasters are no longer named individually (rather, they share the
> common rasterset name and are identified by the associated
> values of the arbitrary parameters), to access a specific raster
> one would need to issue a query. (Much like accessing a table's
> row with SQL queries.)
> Certainly, to expose the very exciting new features the
> rasterset model could offer, the UI (both the command line and
> the graphical parts) would require a major overhaul. However,
> for the compatibility's sake, it's reasonable to implement the
> current raster accessing interface on top of the rasterset
> facility, thus allowing for the existing code (and therefore
> interface) to be retained.
> Then, there would have to be a mapping of the compatibility
> raster names to the (rastername, parameters) pairs, and the
> corresponding utilities to manage it, both in the library API
> and the UI, like:
> GRASS> r.bind \
> raster=compat-airs-2007-05-31-total-ozone.qa \
> rasterset=airs-total-ozone \
> parameter="timestamp=2007-05-31 21:35:24 +0000" \
> parameter="qaflags_p=true"
> Parameters not specified are to be allowed to match all, but not
> any, of the rasters. Thus, it won't be needed to specify the
> individual tile indices for the tiled rasters to mean the whole
> spatial extent of the rasterset. If several rasters match the
> specification, but do not complement each other spatially, an
> error is signalled, like:
> GRASS> r.bind \
> raster=dummy \
> r.bind: several rasters match the specification
> GRASS>
> Importing utilities (r.in.gdal, or r.import) would need to be
> changed early to allow for both the rasterset name and the
> identifying parameters to be specified. The other modules could
> be changed as the time permits.
> The rasters imported may be automatically named according to an
> arbitrary user-specified scheme with the ``hooks'' facility
> being implemented in GRASS. (I hope to present my ideas
> regarding such a facility in a separate posting.)
> * Notes for the implementor
> The model described above could be based on the current 2D
> rasters implementation after cleaning it of the extra features
> to be provided by the rasterset model itself.
> Within the model, the 2D rasters facility is the lower level,
> and its interface would need to be changed. For the
> compatibility's sake, the former interface would need to be
> provided by the code layered on top of the rasterset
> implementation.
> The rasterset model is to be implemented mostly from scratch.
> [1] http://grass.gdf-hannover.de/wiki/Time_series_in_GRASS
> [2] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
> [3] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
> [4] http://freegis.org/cgi-bin/viewcvs.cgi/grass/gips/gip-0002.txt?rev=HEAD&co
> ntent-type=text/vnd.viewcvs-markup
> [5] http://trac.osgeo.org/gdal/wiki/rfc4_geolocate
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
