[GRASS-dev] sqlite and grass64
William Kyngesburye
woklist at kyngchaos.com
Sun Jan 13 18:07:21 EST 2008
On Jan 13, 2008, at 5:55 PM, Glynn Clements wrote:
>> AFAIU SQLite (by default) stores the DBs for all vector maps in a
>> single file per mapset. This makes it hard to share individual vector
>> maps and may have LFS issues when your data + mapset gets to be huge.
> It probably wouldn't be hard to modify the SQLite DBMI driver to allow
> one file per map (like for DBF), but then you lose the ability to
> perform joins (OTOH, if you're using DBF, you never had this ability
> in the first place).
I also like the idea of one db file per map. But I didn't know about
the join problem (I can see joins being useful). Perhaps a db extract
command can be added for when one wants to isolate a map's files?
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
