[GRASS-dev] d.legend uses a static buffer for `map='
Ivan Shmakov
ivan at theory.asu.ru
Sun Jan 13 22:31:33 EST 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
>> Things I didn't change with this patch:
>> * buffers related to SQL commands, because I know no appropriate Cpp
>> macro for these;
> I would suggest just adding e.g.:
> #define SQL_COMMAND_MAX 4000
> to the top of the file, then using that. Although it doesn't provide
> consistency between modules, it makes it easier to find such
> constants if they're at the top of the file.
There're just too many files for this macro to be defined.
Could there be a separate header to define the macros like this
one?
>> * misused G_warning (), etc.; like:
>> there're just too many of these and I hope to handle them with a
>> script;
> Note that those functions are tagged with:
> __attribute__((format(printf,1,2)));
> With gcc, you can use the option:
> `-Wformat-nonliteral' If `-Wformat' is specified, also warn if the
> format string is not a string literal and so cannot be checked,
> unless the format function takes its format arguments as a `va_list'.
> to identify problematic cases (although --with-nls will interfere
> with this).
It much more a problem to get them changed automatically than to
get them identified.
