[GRASS-dev] what if: Anything series?
Markus Neteler
neteler at osgeo.org
Mon Jan 14 06:37:58 EST 2008
On Jan 14, 2008 10:57 AM, Ivan Shmakov <ivan at theory.asu.ru> wrote:
> >>>>> Markus Neteler <neteler at osgeo.org> writes:
> >> Take a look at the minor change for lib/insert_raster.sh as well
> >> (attached.)
> > Looks much more polished. But it looks like bash to me, right? So
> > far we try to avoid bash-isms in GRASS for portability. Or will it
> > run with ash, too?
> It seems that both `local' and `$(COMMAND)' are available in
> either `dash' or BusyBox' `ash', e. g.:
> $ cat test.sh
> a=
> f () { local a="$1" ; echo "$a" ; }
> f "$(echo Hello, world\!)"
> echo "\"$a\" is expected to be an empty string"
> $ dash test.sh
> Hello, world!
> "" is expected to be an empty string
> $ ash test.sh
> Hello, world!
> It's probably reasonable to require a Shell implementation with
> either once you're depending on Shell functions being available.
> I'm not sure that these constructs are mandated by any standard,
> though.
> The `test' (`[ ... ]') command should be generally available as
> well. IIRC, it's mandated by POSIX.
I would leave this to others - I am not much expert of POSIX.
> >> In particular, I believe that the generic arrays storage facility is
> >> needed in GRASS for a long time. At the very least, the ability to
> >> access arbitrary arrays in `r.mapcalc' expressions sounds quite
> >> appealing to me.
> >> Implementing this facility would effectively split the raster data
> >> set implementation into the generic ``raster'' (or ``array'') part
> >> and the specific ``geospatial'', ``color mapping'', and ``who knows
> >> what'' ones.
> > I do agree that the raster part needs a radical renovation. Some team
> > members also have ideas here - hope it comes true for GRASS 7.
> Are these collected anywhere on the Web (besides of [1, 2])?
> [1] http://grass.gdf-hannover.de/wiki/GRASS_7_ideas_collection
> [2] http://grass.gdf-hannover.de/wiki/Replacement_raster_format
AFAIK some material was collected in the Wiki from mailing
list discussions:
http://lists.osgeo.org/pipermail/grass-dev/
More is scattered around in the list archive.
(use e.g.
http://www.nabble.com/forum/Search.jtp?query=raster+format&sort=date&local=y&forum=1200
to find more).
Markus
