[GRASS-dev] Python GUI requirements
Martin Landa
landa.martin at gmail.com
Mon Jan 14 07:03:09 EST 2008
2008/1/14, Glynn Clements <glynn at gclements.plus.com>:
> > current trunk ./configure --help says that --with-python will enable
> > Python support (Python bindings?).
> Yes.
> > Still I don't see any switch to enable/disable wxpython. Shouldn't
> > there be one?
> It isn't needed. The Tcl/Tk and Python checks in gui/Makefile are both
> bogus; those directories should be processed regardless of whether or
> not Tcl/Tk or Python are installed on the build system.
now gui/Makefile checks for wxPython instead of Python. wxPython stuff
is installed only if --with-wxpython is given.
Martin
> The Tcl/Tk check is meant for code which links against the Tcl/Tk
> libraries, namely NVIZ, v.digit and the form library.
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
