[GRASS-dev] sqlite and grass64
Moritz Lennert
mlennert at club.worldonline.be
Mon Jan 14 08:02:07 EST 2008
On 14/01/08 00:55, Glynn Clements wrote:
> It probably wouldn't be hard to modify the SQLite DBMI driver to allow
> one file per map
Why would you have to modify the driver ? You can already do so by
setting v.db.connect to a seperate file. So, it's more a question of
what should be done by default than allowing it, or do I misunderstand
something ?
Moritz
