[GRASS-dev] Re: [GRASS-user] Unable to create new project with Grass
Michael Barton michael.barton at asu.edu
Mon Jan 14 10:37:29 EST 2008
Jan,
Is EPSG location creation the only thing that fails? Can you create
locations from georeferenced files and by specifying projection
parameters?
I just tried creating a location from EPSG code 4326 and it worked
fine in GRASS 6.3 compiled a few days ago. I don't know if this is a
problem related to 6.2 or not
Glynn Clements discussed a problem with shared libraries in Linux
that might or might not be a help. I am copying it below.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
======== shared library post ==============
Date: Sun, 13 Jan 2008 23:34:52 +0000
Subject: Re: [GRASS-user] Error creating new mapset
To: "Jose A. Ruiz-Arias" <jararias at ujaen.es>
Cc: grass-user at lists.osgeo.org
Message-ID: <18314.40988.419833.583423 at cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
Jose A. Ruiz-Arias wrote:
> i have installed GRASS-6.2.3 from source code with no apparent
> errors during
> configuration, compilation and installation. However, when i run
> grass and
> try to create a new mapset i get next error:
> g.region: error while loading shared libraries: libgdal.so.1:
> cannot open
> shared object file: Error 40
> In fact, when i was setting the projection parameters and chose a UTM
> projection, the program did not ask me for the UTM zone, the
> ellipsoid and
> the datum.
> In the GRASS configure process I explicitely used the
> flag --with-gdal=/usr/local/bin/gdal-config and there were no
> errors. I
> checked for the shared library and it is placed in /usr/local/lib
> directory.
> Before the GRASS installation, I installed the GDAL/OGR bundle from
> the source
> code, with netcdf support, and the GRASS support disabled. Again,
> there were
> no apparent errors. Next I installed the gdal-grass plugin (gdal-
> grass-1.4.3
> with the following options:
> configure --with-gdal=/usr/local/bin/gdal-config --with-grass=/usr/
> local/grass-6.2.3)
> I did not detect any problem during the installation of these
> bundles. Anyone
> knows about the problem??
Most systems won't load shared libraries from /usr/local/lib without
some additional configuration.
For Linux, you need to either set the LD_LIBRARY_PATH environment
variable to a path which includes /usr/local/lib, or add
/usr/local/lib to /etc/ld.so.conf then run ldconfig (as root).
On Jan 14, 2008, at 7:49 AM, Jan Schorn wrote:
> Hi Michael,
> creating mapsets in an existing locations is no problem, and
> everything in GRASS we did worked fine. Its possible to see the
> locations, mapsets and everything.
> But it's still not posible to create a location using EPSG codes (y
> tried various, 4326 too) - neither the directory is created (GRASS
> versions: 32bit 6.2.3 and 64bit 6.2.2).
> With QGIS there aren't any problems creating Locations. This was
> the only way i could create Locations with the Ubuntu-Packages.
> I'm running GRASS compiled from source on one of the computers and
> there aren't any problems too.
> Thanks for troubleshooting ;-)
> Jan
> Michael Barton escribió:
>> First, try an already created location. Put the location of one of
>> the demo data sets into your grass data directory and try to see
>> it. Once you can see it OK, quit GRASS (GUI and typing exit from
>> the command line), restart GRASS, and try to create a mapset in
>> the demo location. If that works, quit GRASS, restart GRASS, and
>> try creating a dummy location using EPSG code.
>> Sorry for the complications, but this can help troubleshoot the
>> problem.
>> Michael
>> Phone: 480-965-6262
>> Fax: 480-965-7671
>>>> On Jan 13, 2008, at 5:06 AM, grass-user-request at lists.osgeo.org
>>>> wrote:
>>>>> Date: Sat, 12 Jan 2008 21:26:05 +0000
>>>>> From: "Jan Schorn" <js.mailinglists at gmail.com>
>>>>> Subject: Re: [GRASS-user] Unable to create new project with Grass
>>>>>     6.2.2 in    Ubuntu 7.1
>>>>> To: grass-user at lists.osgeo.org
>>>>> Message-ID:
>>>>>     <ec1e03600801121326q3ce98d3ex1cf0a93072832dca at mail.gmail.com>
>>>>> Content-Type: text/plain; charset="iso-8859-1"
>>>>> Hi, list
>>>>> I installed GRASS 6.2.3 in about 14 computers with i368
>>>>> architecture and
>>>>> Ubuntu 7.10 (Les-ejk repositorios). The only way to create a
>>>>> new Location is
>>>>> using QGIS.
>>>>> Using GRASS the error explained by Matt occurs.
>>>>> ¿Any ideas?
>>>>> Thanks,
>>>>> Jan
>>>>> 2008/1/11, Matt <mlpublic42 at gmail.com>:
>>>>>> I am unable to create a new location/project in Grass.  Since
>>>>>> I am new to
>>>>>> both Linux/Ubuntu and Grass there are a nearly infinite ways
>>>>>> to go wrong.  I
>>>>>> have Ubuntu 7.10 installed.  I used Synaptic to install Grass
>>>>>> 6.2.2 .  I
>>>>>> have been able to start Grass and play with the Spearfish and
>>>>>> North Carolina
>>>>>> datasets.  I've made it to page 37 in "Open Source GIS A Grass
>>>>>> GIS Approach,
>>>>>> 3rd ed."  As interesting as North Carolina is, I yearn to
>>>>>> create a map of
>>>>>> western New York.  But when I try to create a new project
>>>>>> closer to home, I
>>>>>> get nowhere.  All the tutorials I've come across treat this as
>>>>>> trivial, but
>>>>>> I'm stuck!
>>>>>> Starting Grass from the "Run Application" applet ("run in
>>>>>> terminal" box
>>>>>> checked), starts Grass in the terminal window and a Grass
>>>>>> Startup GUI window
>>>>>> appears.  Using the Browse button I enter "/home/matt/grass/
>>>>>> grassdata" in
>>>>>> the GIS Data Directory box.  The previous created directory
>>>>>> map1 appears in
>>>>>> the project location box and the Accessible Mapsets window is
>>>>>> empty.  At
>>>>>> this point I've tried several things.  If before starting
>>>>>> Grass I put a
>>>>>> Tiger shp file ( tgr36029lkA.shp) into map1, I'm unable to use
>>>>>> it.  If I
>>>>>> click on EPSG codes and select 4326 and click "Define
>>>>>> Location" it tells me
>>>>>> to restart Grass to find the created location.  When restarted
>>>>>> the location
>>>>>> is not there.
>>>>>> Any ideas?  Especially how to start a new project using a
>>>>>> Tiger shape
>>>>>> file? (Remember, novice).
>>>>>> Thanks,
>>>>>> Matt
>>>> Given what you've described, it seems that somehow you've gone
>>>> too far down the directory tree. You've got your mapset
>>>> appearing in the location list. This will be an invalid
>>>> "location" because it does not contain a PERMANENT directory
>>>> (i.e., mapset). Try backing up the tree one level. Your new
>>>> location probably exists at the next level up.
>>>> Go back to browse in the data directory selection. It may be the
>>>> difference between a single click and double click. But you want
>>>> to get the proper directory in the directory selection dialog
>>>> box. (In the case above, it should be /home/matt/grass/grassdata
>>>> *IF* that is where your location directories are stored. That
>>>> is, the nc_spm_07 directory should be inside /home/matt/grass/
>>>> grassdata.) Then press OK to return to the startup screen.
>>>> At this point, you should seek nc_spm_07 on the left side and
>>>> PERMANENT, landsat, sqlite, and user1 on the right side. If this
>>>> is NOT what you see, redo your data directory selection until it
>>>> IS what you see. At this point you can either 1) create a new
>>>> mapset INSIDE nc_spm_07 (or other locaiton), or 2) create a new
>>>> LOCATION inside your data directory.
>>>> You should not have to restart GRASS anymore to see a newly
>>>> created location or mapset (this instruction is out of date
>>>> AFAIK). If you cannot see a new location or mapset, try
>>>> reselecting your data directory (i.e., the same one you are
>>>> creating a location in).
>>>> There is very good online help on all this directly accessible
>>>> from the startup screen by pressing the "Help" button.
>>>> Michael_______________________________________________
>>>> grass-user mailing list
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> Hi Micheal,
>>> Thanks for your answer, but in my case the 'nc_spm_07' directory
>>> is not being created. The directory doesn't appear neither '/home/
>>> matt/grassdata' and nor in '/home/matt'.
>>> I tried the same with the grass packages from the ubuntu
>>> repositorios for the 64bit version, and problem also occurs
>>> The epsg file exists in both cases (/usr/share/proj/epsg). There
>>> is no error message.
>>> I'm working with a GRASS version compiled from source and never
>>> had this problem.
>>> Jan
