[GRASS-dev] Re: [GRASS GIS] #22: Grass r.out.mat 64bit Matlab
reading problem
trac at osgeo.org
Wed Jan 23 00:09:00 EST 2008
#22: Grass r.out.mat 64bit Matlab reading problem
Reporter: alexice | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: minor | Milestone: 6.3.0
Component: default | Version: 6.2.3
Resolution: | Keywords:
Comment (by 1gray):
Replying to [comment:1 hamish]:
> raster/r.out.mat/main.c:
> The mrows, ncols, format_block, and realflag variables are type "long"
and written with fwrite(...,sizeof(long),...);. They should be written as
4 bytes on all platforms. The name_len variable too.
The file should `#include <stdint.h>' and use int32_t instead of
`long' where the bit width is important.
> I think it's an easy fix but I have only passing exposure to 64bit
programming. I don't have a 64bit machine to test on, but I do have matlab
2007a.
At the very least, the s/long/int32_t/ change (where appropriate)
shouldn't break the 32-bit build. Could you check it? (I have access to
a 64-bit host, but not to Matlab.)
> r.in.mat uses fread() + "long" integers for those things too, so would
need to be fixed as well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/22#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
