[GRASS-dev] Re: missing awk in WinGRASS
Gerald Nelson
gnelson at uiuc.edu
Wed Jan 23 14:56:32 EST 2008
We have done a few tiny experiments with running scripts written for a linux
bash environment from wingrass started from within msys. One thing that
doesn't work is bc, the bash calculator. If you ask msys what kind of shell
it has, it says sh, rather than bash.
The GnuWin32 website, http://gnuwin32.sourceforge.net/packages.html, has a
bc program which we will try.
Jerry
-----Original Message-----
[mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Moritz Lennert
Sent: Wednesday, January 23, 2008 1:47 PM
To: Michael Barton
Cc: GRASS developers list
Subject: [GRASS-dev] Re: missing awk in WinGRASS
On 23/01/08 20:35, Michael Barton wrote:
> OK. We can do that. Thanks.
> Is msys needed for any other aspects of GRASS -- i.e., is it required to
> run it? Or is it only needed if you want to do the scripts?
Only for the scripts. And even for those it doesn't have to be msys. You
could install the individual components (a shell like bash, awk, sed,
etc) separately, e.g. from GnuWin32. As long as these tools are in your
path, this should work.
Moritz
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
