[GRASS-dev] why d.vect.thematic won't run on WinGRASS - d.mon
problem
Glynn Clements
glynn at gclements.plus.com
Thu Jan 24 05:53:51 EST 2008
Michael Barton wrote:
> > If you just want d.vect.thematic to work with WinGRASS, changing it to
> > use GRASS_RENDER_IMMEDIATE=TRUE instead of "d.mon start=PNG" would
> > probably be less work than getting monitors working.
> In fact, we recently had to change d.vect.thematic to set
> GRASS_RENDER_IMMEDIATE=FALSE so that it's multiple iterations of
> d.vect would composite in the PNG monitor and then be output as a PNG
> to the GUI.
You can use GRASS_PNG_READ=TRUE to have it read an existing file at
startup, rather than starting with a blank "screen". That way, each
command will overlay the output from previous commands.
