[GRASS-dev] why d.vect.thematic won't run on WinGRASS - d.mon
problem
Michael Barton
michael.barton at asu.edu
Thu Jan 24 14:07:15 EST 2008
I'm going to try this as soon as I can steal a bit of time. I'm
somewhat uncertain how to get the initial PNG for GRASS_PNG_READ.
I can create a dummy temp map using r.mapcalc and then save it to a
PNG using r.out.png. But I need to make sure that it's background is
transparent so that the final composite can overlay whatever is in the
map display. Any suggestion for how I do that?
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 24, 2008, at 8:40 AM, Moritz Lennert wrote:
> On 24/01/08 16:30, Michael Barton wrote:
>> So it builds the PNG as it goes, and then the TclTk GUI could grab
>> the completed composite when it's done?
> That's how I understand the docs. Just watch out to set
> GRASS_PNG_READ back to FALSE after d.vect.thematic finishes...
>> This sounds almost too good to be true.
> Glynn is too good to be true ;-)
> Moritz
