[GRASS-dev] svn seems to complete commit to repository,
but hang locally
Markus Neteler
neteler at osgeo.org
Fri Jan 25 14:23:45 EST 2008
On Jan 25, 2008 6:35 PM, Patton, Eric <epatton at nrcan.gc.ca> wrote:
> I'm having trouble with svn today...for some reason, the svn commit hangs at "Transmitting file data ." even though the commit seems to have been completed and is browse-able on the repository. Has anyone had trouble uploading commits? Server problem, maybe?
Eric,
I was told that this happens when the CIA IRC bot hangs
(http://cia.vc/stats/project/GRASS).
The SVN server should be ok. If you can access IRC, you could in those moments
irc://irc.freenode.net/osgeo
or
irc://irc.freenode.net/telascience (preferred). Then the OSGeo
sysadmins could check.
Markus
