[GRASS-dev] Re: [GRASS GIS] #13: GRASS OGR Module failing
trac at osgeo.org
Sat Jan 26 09:23:01 EST 2008
Reporter: jrobins | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.3.0
Component: default | Version: svn-trunk
Resolution: | Keywords: OGR,Cygwin,winGRASS,Tcl/Tk
Old description:
> The GDAL/OGR module fails when I try to export ESRI shapefiles from GRASS
> vectors.
> Cygwin/X Output on startup:
> Welcome to the XWin X Server
> Vendor: The Cygwin/X Project
> Release: 6.8.99.901-4
> Contact: cygwin-xfree at cygwin.com
> XWin was started with the following command line:
> X :0 -multiwindow -clipboard
> _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root
> winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1
> (II) XF86Config is not supported
> (II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more
> information
> winDetectSupportedEngines - Windows NT/2000/XP
> winDetectSupportedEngines - DirectDraw installed
> winDetectSupportedEngines - DirectDraw4 installed
> winDetectSupportedEngines - Returning, supported engines 00000007
> winSetEngine - Multi Window or Rootless => ShadowGDI
> winAdjustVideoModeShadowGDI - Using Windows display depth of 32 bits per
> pixel
> winAllocateFBShadowGDI - Creating DIB with width: 1280 height: 800 depth:
> 32
> winFinishScreenInitFB - Masks: 00ff0000 0000ff00 000000ff
> winInitVisualsShadowGDI - Masks 00ff0000 0000ff00 000000ff BPRGB 8 d 24
> bpp 32
> null screen fn ReparentWindow
> null screen fn RestackWindow
> InitQueue - Calling pthread_mutex_init
> InitQueue - pthread_mutex_init returned
> InitQueue - Calling pthread_cond_init
> InitQueue - pthread_cond_init returned
> winInitMultiWindowWM - Hello
> winInitMultiWindowWM - Calling pthread_mutex_lock ()
> winMultiWindowXMsgProc - Hello
> winMultiWindowXMsgProc - Calling pthread_mutex_lock ()
> MIT-SHM extension disabled due to lack of kernel support
> XFree86-Bigfont extension local-client optimization disabled due to lack
> of shar
> ed memory support in the kernel
> (--) Setting autorepeat to delay=500, rate=31
> (--) winConfigKeyboard - Layout: "00000409" (00000409)
> (--) Using preset keyboard for "English (USA)" (409), type "4"
> Rules = "xorg" Model = "pc105" Layout = "us" Variant = "(null)" Options =
> "(null
> (--) 5 mouse buttons found
> Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing
> from li
> st!
> Could not init font path element /usr/X11R6/lib/X11/fonts/100dpi/,
> removing from
> list!
> winPointerWarpCursor - Discarding first warp: 640 400
> winInitMultiWindowWM - pthread_mutex_lock () returned.
> winProcEstablishConnection - Hello
> winMultiWindowXMsgProc - pthread_mutex_lock () returned.
> winInitMultiWindowWM - pthread_mutex_unlock () returned.
> winMultiWindowXMsgProc - pthread_mutex_unlock () returned.
> winInitMultiWindowWM - DISPLAY=127.0.0.1:0.0
> winMultiWindowXMsgProc - DISPLAY=127.0.0.1:0.0
> cat: /home/John/.Xauthority: No such file or directory
> winInitClipboard ()
> winProcEstablishConnection - winInitClipboard returned.
> winClipboardProc - Hello
> DetectUnicodeSupport - Windows NT/2000/XP
> winClipboardProc - DISPLAY=127.0.0.1:0.0
> winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened
> the di
> splay.
> winInitMultiWindowWM - XOpenDisplay () returned and successfully opened
> the disp
> lay.
> winClipboardProc - XOpenDisplay () returned and successfully opened the
> display.
> winProcSetSelectionOwner - Clipboard not yet started, aborting.
> --Execute 'grass62' at xWin prompt--
> Cygwin/X output in Cygwin shell:
> winMultiWindowXMsgProcErrorHandler - ERROR: BadWindow (invalid Window
> parameter)
> parameter)
> --select spearfish60 location; PERMANENT mapset--
> Grass output in xWin shell:
> Cleaning up temporary files.....
> Starting GRASS ...
> /usr/local/grass-6.2.3/etc/Init.sh: line 635: tput: command not found
> Welcome to GRASS 6.2.3 (2007)
> GRASS homepage: http://grass.itc.it/
> This version running thru: GNU Bash (Cygwin)
> (/usr/bin/bash.exe)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> If required, restart the graphical user interface with: gis.m &
> When ready to quit enter: exit
> GRASS 6.2.3 (spearfish60):~ >
> --error is generated here--
> GRASS 6.2.3 (spearfish60):~ > v.out.ogr input=roads type=line
> dsn=/shapefiles olayer=Road
> Segmentation fault (core dumped)
> Output in Cygwin shell:
> 24 [main] v.out.ogr 2480 _cygtls::handle_exceptions: Error while
> dumping st
> ate (probably corrupted stack)
> --data dumped to v.out.ogr.stackdump in my home directory
> (c:\cygwin\home\John\)--
> Is this an OGR problem, or is this a GRASS issue? It started happening
> recently, but I can
> now reproduce it reliably. I am running GRASS 6.2.3 on Windows Vista
> using all the latest updates
> from Cygwin (v. 1.5.25-7), from the Cygwin/X Project (v. 6.8.99.901-4),
> and from GDAL
> (v. 1.3.1-1).
> Thanks,
> John R.
New description:
vectors.
information
pixel
32
bpp 32
of shar
"(null
from li
st!
removing from
list!
winInitClipboard ()
the di
splay.
the disp
lay.
display.
parameter)
parameter)
Starting GRASS ...
(/usr/bin/bash.exe)
dumping st
recently, but I can
and from GDAL
(v. 1.3.1-1).
Thanks,
John R.
Ticket URL: <http://trac.osgeo.org/grass/ticket/13#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
