[GRASS-dev] svn seems to complete commit to repository, but hang
locally
Frank Warmerdam
warmerdam at pobox.com
Sun Jan 27 13:20:17 EST 2008
Hamish wrote:
> Hamish:
>>> Something I miss from the old GRASS ViewCVS web interface was the
>>> "annotate" tool, to see in which rev a change was introduced.
>>> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/
>>> the new SVN-ViewCVS mirror does not have it:
>>> http://josef.fsv.cvut.cz/cgi-bin/viewcvs.cgi/grass/
> Martin:
>> sorry, I don't understand, comparing
>> and
> http://josef.fsv.cvut.cz/cgi-bin/viewcvs.cgi/grass/trunk/?root=grass-osgeo
> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/display/d.ask/main.c
> "Revision 2.4 / (as text) / (view) - annotate - [select for diffs] ,"
> http://josef.fsv.cvut.cz/cgi-bin/viewcvs.cgi/grass/trunk/display/d.ask/main.c?rev=23493&root=grass-osgeo&view=log
> "Revision 23493 - (view) (download) (as text) - [select for diffs] "
Folks,
For what it's worth, you can get a report from subversion indicating the
last person to touch each line of code using the "svn blame" command.
eg.
svn blame xmlreformat.cpp
4585 warmerda CPLFree( pszRawXML );
4588 warmerda CPLDestroyXMLNode( poTree );
4585 warmerda }
8351 dron
8351 dron return 0;
2859 warmerda }
11940 warmerdam
The first column is the revision in which the line was changed, and the
second column is the userid responsible. My understanding is that this
will appear as an option in the Trac browser in a future version which i'm
quite looking forward to.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
