[GRASS-dev] what does zoom= do?
Michael Barton michael.barton at asu.edu
Sun Jan 27 23:45:35 EST 2008
On Jan 27, 2008, at 9:07 PM, grass-dev-request at lists.osgeo.org wrote:
> Now what does 'g.region align=' do?
> Hamish
This one I can answer. When you zoom, g.region has to maintain an
integer number of rows and columns. Without -a, it will find the
nearest integer for the rows and columns given the extents and
resolution specified. Then it will slightly adjust the resolution so
that the specified extents are exactly divisible by the calculated
integer number or rows and columns.
With -a, g.region will slightly adjust the extents (instead of the
resolution) to come up with an integer number or rows and columns as
close as possible to the selected extents while exactly maintaining
the specified resolution.
Try it by running g.region -ugp after setting a region to specified
extents and resolution with and without -a. Without -a, the
resolution will differ slightly from those specified, but the extents
will exactly match those specified. With -a, the resolution will
exactly match and the extents will differ slightly.
However, -a is ignored if the resolution is not specified. I asked
that in circumstances where resolution is not specified and -a is
used, g.region align to the current resolution, whatever it is.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
