[GRASS-dev] v.univar question: Why not lines and areas?
Moritz Lennert
mlennert at club.worldonline.be
Mon Jan 28 07:50:33 EST 2008
On 27/01/08 20:30, Michael Barton wrote:
> v.univar only works with points. But since it is calculating stats on a
> field in the attributes table, it should work the same for all vector
> objects. Can we get rid of the limitation that it only works with points?
There was some debate [1] about the statistical validity of working with
the other types, as the way it was programmed, the statistics were
calculated with weights which corresponded to line length / area surface .
I guess we might want to distinguish between a v.univar which works on
the actual vector objects from a v.db.univar which works on any
arbitrary attribute (or combination of attributes). We could write a
C-replacement of the current v.db.univar script on the base of the code
I have for the classification algorithms used in v.class.
As mentioned earlier, it might be better that I move the code from
v.class into a library which can then be accessed by different modules...
Currently, I have defined the following statistics:
typedef struct
double count;
double min;
double max;
double sum;
double sumsq;
double mean;
double var;
double stdev;
} STATS;
But this could easily be extended according to needs and v.db.univar
could also use the quantile classification algorithm to extract percentiles.
What are the statistics most people need ?
Moritz
[1] http://lists.osgeo.org/pipermail/grass-dev/2004-July/014976.html
