Fwd: [GRASS-dev] d.histogram: font issue
Michael Barton
michael.barton at asu.edu
Thu Jan 31 00:15:43 EST 2008
I noted a problem with the fonts in d.histogram and sent a note to
Hamish, mistakingly thinking he had been working on it. He suggested
that I copy the dev list. So here it is.
Michael
Begin forwarded message:
>> Your fix on the tick marks looks nice. There is still something odd
>> with the fonts. Here is a screenshot. Also, the font does not scale
>> with the screen size.
> actually Markus fixed it, not me.
> the bug report for this:
> http://intevation.de/rt/webrt?serial_num=1977
>> Here is a little more info. When I initially run d.hist and
>> display it
>> (I'm doing it in a TclTk canvas), all the letters are in a large font
>> and bunched up. If I expand the window (i.e., redraw d.hist with
>> larger
>> GRASS_WIDTH and GRASS_HEIGHT), the letters space out correctly, but
>> appear in different sizes (what I sent you). If I then resize back
>> down
>> to smaller, the letters eventually go back to a single font and begin
>> to resize themselves with window size. Resizing the TclTk canvas
>> cases
>> a change to the width and height variables, and a redraw of d.hist. I
>> don't know if this is helpful or not.
>> Now I see why the letters are all squished together. This happens if
>> the region is roughly square or especially if it is taller than it is
>> wide. If the region is considerably wider than it is tall (e.g. 3:2)
>> the letters look OK. It looks like it is using the region height to
>> specify the typeface point size, and the region width to specify the
>> leading or horizontal character spacing. It should probably use the
>> width only for character point size.
> cc -dev?
> apparently the fonts are scaled per number. I had the same problem in
> d.legend until I made it scan for the longest number of characters
> before
> deciding the scaling amount. A similar approach could be taken here.
> (disclaimer: I don't know if anyone would have ever noticed this,
> but you can recreate the same effect in d.legend if you flip the
> legend upside down so the smallest(shortest # of chars) values are
> at the top)
> The module is rerun every time the window is resized, so it isn't
> surprising that the auto-scaling code will give a different result.
> I support using some Python plotting library to draw axes. We could
> write
> up a grid template using d.graph, but I'd rather be in the business of
> gluing together high quality components rather than reinventing
> yet-another x-y plotting package. If we like a plotting package but
> it lacks the ability to output to PNG or whatever we need, I would
> suggest donating the extra code to enhance that package to the
> other project.
> Your histogram demo looked nice. Next step: add g.parser support
> and replace random number generated data with results of r.stats.
> r.what.color could be used to get the colors for the midpoint of
> each bin.
