[GRASS-dev] Re: [GRASS-user] installation problems in user space
Glynn Clements
glynn at gclements.plus.com
Tue Jul 1 12:16:10 EDT 2008
Abhinandan Raghavan wrote:
> However, when I run make for grass, I get:
> Errors in: /home/abhi/lib/grass/visualization/nviz
> Finished compilation: Tue Jul 1 10:56:29 CEST 2008
> (In case of errors please change into the directory with error and run
> 'make')
> make: *** [default] Error 1
> I tried going into "/home/abhi/lib/grass/visualization/nviz" and running
> make there and I get the following error:
> make[1]: *** [OBJ.x86_64-unknown-linux-gnu/nvizAppInit.o] Error 1
> make[1]: Leaving directory `/home/abhi/lib/grass/visualization/nviz/src'
> make: *** [nvwish] Error 2
I need to see the lines before that; everything from the last gcc
command onward.
