[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Tue Jul 1 22:23:43 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: terraflow r.terraflow
Platform: Unspecified | Cpu: Unspecified
Comment (by adanner):
Replying to [comment:9 glynn]:
> Replying to [comment:8 adanner]:
> > > Correct. Which is why the interface needs to be fixed in C; i.e. add
the "const" to the fields of "struct Option" in gis.h. Having the compiler
remind people about this on a regular basis is the best way to make it
happen.
> > > Actually, I'll look into that side of it now.
> > Thanks, that eliminates many of the warnings. There are only four left
on options->answer, but I'm content with only four warnings. Fixing those
last four require some tedious buffer creation/copying.
> It should suffice to use:
> opt->answer = G_store("literal");
Another rounds of updates to the patch to use G_store. It works great for
r.terraflow which now compiles against gcc 4.2.3 with zero warnings.
Thanks for your help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:10>
