[GRASS-dev] [GRASS GIS] #206: SQL builder prints the name of the vector map to the terminal
GRASS GIS trac at osgeo.org
Wed Jul 2 05:53:48 EDT 2008
 Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect    |      Status:  new
 Priority:  major     |   Milestone:  6.4.0
Component:  wxGUI     |     Version:  svn-develbranch6
 Keywords:            |    Platform:  Linux
      Cpu:  x86-64    |
 1. add a vector map
 2. right click it on the list > "Show attribute data"
 3. check "Advanced"
 4. press "SQL Builder"
 The vector map's name is printed to the terminal which should not take
 place. Also, as you click around errors "(python:5988): Gtk-WARNING **:
 gtk_widget_size_allocate(): attempt to allocate widget with width -5 and
 height 15" are printed too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/206>
