[GRASS-dev] grass6_devel, problems to find gdal library
Massimo Di Stefano
massimodisasha at yahoo.it
Fri Jul 4 09:46:25 EDT 2008
Hi
i'm tring to update grass from svn, on osx .
the configure find gdal-config
but fail to find gdal libraries
checking for location of JPEG includes... /Library/Frameworks/
UnixImageIO.framework/unix/include
checking for jpeglib.h... yes
checking for location of JPEG library... /Library/Frameworks/
UnixImageIO.framework/unix/lib
checking for jpeg_start_compress in -ljpeg... yes
checking whether to use GDAL... yes
checking for gdal-config... /Library/Frameworks/GDAL.framework/
Programs/gdal-config
configure: error: *** Unable to locate GDAL library.
using the same configure (and the same gdal libraries)
on the svn code downloaded 2 weeks ago
(i don't know how to check the exact release it is),
it works as aspected
thanks for any suggestion,
regards
Massimo Di Stefano.
Chiacchiera con i tuoi amici in tempo reale!
http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
