[GRASS-dev] grass6_devel, problems to find gdal library
Glynn Clements
glynn at gclements.plus.com
Fri Jul 4 13:28:48 EDT 2008
Massimo Di Stefano wrote:
> i'm tring to update grass from svn, on osx .
> the configure find gdal-config
> but fail to find gdal libraries
> checking for location of JPEG includes... /Library/Frameworks/
> UnixImageIO.framework/unix/include
> checking for jpeglib.h... yes
> checking for location of JPEG library... /Library/Frameworks/
> UnixImageIO.framework/unix/lib
> checking for jpeg_start_compress in -ljpeg... yes
> checking whether to use GDAL... yes
> checking for gdal-config... /Library/Frameworks/GDAL.framework/
> Programs/gdal-config
> configure: error: *** Unable to locate GDAL library.
Look in config.log for the command which fails and any error messages
which it generates.
