[GRASS-dev] Re: new v.in.geonames: problems with UTF-8 Unicode
text
Markus Neteler
neteler at osgeo.org
Mon Jul 7 15:28:51 EDT 2008
On Mon, Jul 7, 2008 at 8:34 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> It also means that, for VARCHAR columns, you cannot determine the
> maximum width that can be stored in the column.
But doesn't v.in.ascii scan for column lengths in any case?
Maybe make that switchable and use the extracted info?
in point.c:
/* Analyse points ascii file. Determine number of columns and column types.
* ascii_tmp: write copy of tempfile to ascii_tmp:
* rowlength: maximum row length
* ncolumns: number of columns
* minncolumns: minimum number of columns
* column_type: column types
* column_length: column lengths (string only)
int points_analyse(FILE * ascii_in, FILE * ascii, char *fs,
int *rowlength, int *ncolumns, int *minncolumns,
int **column_type, int **column_length, int skip_lines,
int xcol, int ycol, int region_flag)
Markus
