[GRASS-dev] compile error on wx vdigit
Martin Landa landa.martin at gmail.com
Tue Jul 8 13:04:56 EDT 2008
cd gui/wxpython/vdigit
rm grass6*
make clean;make
Should help.
Martin
2008/7/8 Moritz Lennert <mlennert at club.worldonline.be>:
> I get the following error trying to compile wxpython vdigit:
> ~/SRC/GRASS/grass_trunk/gui/wxpython/vdigit$ make
> c++ -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -g
> -O2   -fPIC -I/usr/include -I/usr/include/python2.4 -I/usr/include/python2.4
> -fno-strict-aliasing -DNDEBUG -g -O2 -Wall -Wstrict-prototypes
> -I/usr/lib/wx/include/gtk2-unicode-release-2.8 -I/usr/include/wx-2.8
> -D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D_LARGEFILE_SOURCE=1 -D__WXGTK__
> -pthread   -DPACKAGE=\""grasslibs"\"
> -I/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-gnu/include -o
> OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o -c grass6_wxvdigit_wrap.cpp
> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
> Ada/C/ObjC but not for C++
> grass6_wxvdigit_wrap.cpp: In function 'PyObject*
> _wrap_DisplayDriver_UpdateSettings(PyObject*, PyObject*)':
> grass6_wxvdigit_wrap.cpp:11008: error: no matching function for call to
> 'DisplayDriver::UpdateSettings(long unsigned int&, bool&, long unsigned
> int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&, long
> unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&, bool&,
> long unsigned int&, bool&, long unsigned int&, bool&, long unsigned int&,
> bool&, long unsigned int&, bool&, long unsigned int&, bool&, long unsigned
> int&, int&)'
> driver.h:210: note: candidates are: void DisplayDriver::UpdateSettings(long
> unsigned int, bool, long unsigned int, bool, long unsigned int, bool, long
> unsigned int, bool, long unsigned int, int)
> make: *** [OBJ.i486-pc-linux-gnu/grass6_wxvdigit_wrap.o] Erreur 1
> Any hints ?
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
