[GRASS-dev] v.net.alloc / v.net.iso: very long running time
Moritz Lennert mlennert at club.worldonline.be
Wed Jul 9 07:07:34 EDT 2008
Hello,
I'm testing some of the vector network features and am confronted with
an extremely long running time.
Using the North Carolina data set, I start out by adding the schools
into the street network:
v.net input=streets_wake at PERMANENT points=schools_wake at PERMANENT
output=streets_schools_net operation=connect alayer=1 nlayer=2 thresh=200
Then trying either
v.net.alloc input=streets_schools_net output=subnets alayer=1
nlayer=2 ccats=37,127,135,59,38-39,159
or a similar v.net.iso command, I get
Building graph...
Registering arcs...
  100%
Flattening the graph...
Graph was built
Number of centres: [7] (nlayer: [2])
Calculating costs from centres...
and then a percentage indication which stays at 0% for a very long
time... I actually let the module run for a night and it still hadn't
advanced much.
Cutting the network to a small region makes the programs run. So there
seems to a severe efficiency problem in the algorithms used which grows
very quickly with file size...
Moritz
