[GRASS-dev] nvizlib compile error
Wed Jul 9 23:45:24 EDT 2008
Martin Landa wrote:
> > Now it compiles, but when I display the elevation map from the NC data set
> > and then chose the nviz tool in the map display, the entire wx gui
> > crashes...
> > Just found out why: it's a locale problem. LANG is set to fr_BE.UTF-8 on my
> > system. When I set it to C nviz runs (great job !!), but when I leave the
> > default setting, wxgrass crashes and I get the following error in the
> > terminal window where I launch g.gui:
> > GRASS_INFO_ERROR(22238,1): région pour le jeu de données (mapset) courant
> > ligne 1: <n-s resol: 29.349241>
> > GRASS_INFO_ERROR(22238,1): lancer "g.region"
> > GRASS_INFO_END(22238,1)
> right, it crashes when LC_NUMERIC != "C",  calling G_scan_resolution()
LC_NUMERIC affects the format which scanf("%f") etc understands. If
it's set to a locale which uses a comma as the decimal separator, any
GRASS function which tries to read floating-point values which use a
period (i.e. many of GRASS' internal file formats) will fail.
This isn't a problem for normal GRASS modules, as GRASS modules (and
library functions) never call setlocale(LC_NUMERIC). It is a problem
if you're using GRASS library functions from within a program which
sets LC_NUMERIC from the environment (I suspect that this includes the
Python interpreter).
> http://trac.osgeo.org/grass/browser/grass/trunk/lib/gis/rd_cellhd.c#L258
> quick fix
> http://trac.osgeo.org/grass/changeset/32063
A more general fix would be to call setlocale(LC_NUMERIC,"C") from
e.g. gisinit() (in lib/gis/gisinit.c). Otherwise, we will probably end
up running into this issue repeatedly.
