[GRASS-dev] Re: r.series, r.terraflow, simwe
Wed Jul 9 23:51:23 EDT 2008
Paul Kelly wrote:
> >> it before Will moves r.terraflow into the iostream directory as
> >> suggested by Paul.
> > Can you provide details?
> Will is working on a new r.viewshed module which uses the same iostream
> C++ library as r.terraflow. To avoid code duplication I suggested this
> layout:
> Have a subdirectory:
> raster/iostream/
> and within that lib/ r.terraflow/ r.viewshed/
> One copy of the library in the lib directory - it compiles into a static
> library which is then linked in by r.terraflow and r.viewshed.
> This is subject to revision/better ideas of course - when Will has the
> r.viewshed code ready (I haven't seen it) maybe we can experiment with
> it in grass-addons in the first instance.
I suggest moving the iostream library to lib/iostream, rather than
grouping r.terraflow and r.viewshed together.
