[GRASS-dev] Re: [GRASS GIS] #197: sfd support for r.terraflow
trac at osgeo.org
Thu Jul 10 23:00:38 EDT 2008
Reporter: adanner | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Resolution: | Keywords: terraflow r.terraflow
Platform: All | Cpu: All
Comment (by glynn):
Replying to [comment:13 adanner]:
> The makefile should probably be modified to remove libiostream.a on make
clean, but I hate messing with makefiles, so I'll leave that to someone
else.
"make clean" should only remove intermediate files; it shouldn't touch
anything in the dist.<arch> directory.
If you want to force libiostream.a to be remade before making r.terraflow,
mark $(IOSTREAM_DEPLIB) as a .PHONY target, so that it is re-made
regardless of whether or not it already exists.
The same issue applies to every other library in GRASS. However, having
libiostream in the r.terraflow directory seems to lead people to assume
that it will be re-made automatically when making r.terraflow.
For other libraries, most people would be aware that the library needs to
be explicitly re-made before anything which depends upon it. This problem
should go away if libiostream is moved to the lib directory.
Ticket URL: <http://trac.osgeo.org/grass/ticket/197#comment:16>
