[GRASS-dev] Re: new v.in.geonames: problems with UTF-8 Unicode text
Ivan Shmakov
ivan at theory.asu.ru
Fri Jul 11 13:12:23 EDT 2008
>>>>> Glynn Clements <glynn at gclements.plus.com> writes:
> I have made these changes locally (patch attached).
BTW, as some of the changes are actually plain clean-ups, could
they be considered for an ``immediate'' commit?
> Index: db/drivers/sqlite/proto.h
> --- db/drivers/sqlite/proto.h (revision 32073)
> +++ db/drivers/sqlite/proto.h (working copy)
> @@ -1,9 +1,11 @@
> #ifndef __SQLITE_PROTO_H__
> #define __SQLITE_PROTO_H__
> +#include "globals.h"
> /* error.c */
> void init_error ( void );
> -void append_error ( char * );
> +void append_error ( const char * );
> void report_error ( void );
> /* cursor.c */
> Index: db/drivers/sqlite/main.c
> --- db/drivers/sqlite/main.c (revision 32073)
> +++ db/drivers/sqlite/main.c (working copy)
> @@ -11,12 +11,14 @@
> * for details.
> -#define MAIN
> #include <stdlib.h>
> #include <grass/dbmi.h>
> #include "dbdriver.h"
> +sqlite3 *sqlite;
> int main (int argc, char *argv[])
> Index: db/drivers/sqlite/globals.h
> --- db/drivers/sqlite/globals.h (revision 32073)
> +++ db/drivers/sqlite/globals.h (working copy)
> @@ -1,5 +1,8 @@
> #include <sqlite3.h>
> +#ifndef DBMI_SQLITE_PROTO_H
> +#define DBMI_SQLITE_PROTO_H
> /* cursors */
> typedef struct _cursor {
> sqlite3_stmt *statement;
> @@ -12,12 +15,7 @@
> } cursor;
> -#ifdef MAIN
> - sqlite3 *sqlite;
> - dbString *errMsg = NULL; /* error message */
> -#else
> - extern sqlite3 *sqlite;
> - extern dbString *errMsg;
> -#endif
> +extern sqlite3 *sqlite;
> +#endif
> Index: db/drivers/sqlite/error.c
> --- db/drivers/sqlite/error.c (revision 32073)
> +++ db/drivers/sqlite/error.c (working copy)
> @@ -14,8 +14,11 @@
> #include <stdio.h>
> #include <grass/gis.h>
> +#include "proto.h"
> +static dbString *errMsg = NULL; /* error message */
> /* init error message */
> void
> init_error ( void )
> @@ -30,7 +33,7 @@
> /* append error message */
> void
> -append_error ( char *msg )
> +append_error ( const char *msg )
> db_append_string ( errMsg, msg);
