[GRASS-dev] trying to compile wxPython NVIZ
Michael Barton
michael.barton at asu.edu
Mon Jul 14 22:32:46 EDT 2008
Hi Martin,
Finally getting a bit of time. I am trying to compile GRASS 7 so that
I can take a look at the new NVIZ.
I got the following errors again.
/Users/cmbarton/grass_dev/grass7_src/lib/nviz
/Users/cmbarton/grass_dev/grass7_src/gui/wxpython/vdigit
/Users/cmbarton/grass_dev/grass7_src/gui/wxpython/nviz
/Users/cmbarton/grass_dev/grass7_src/visualization/nviz2/cmd
I went to /lib/nviz to check out the error. The result is below. It is
different from the last time it didn't compile, so I hope that this
means that it's getting closer. I'm copying William and Glynn to see
if anyone has suggestions for how to get this working on my Mac. I am
very much looking forward to trying this out.
Michael
================ compile error =================
cmb-MBP-2:grass7_src cmbarton$ cd ./lib/nviz
cmb-MBP-2:nviz cmbarton$ make
cc -dynamiclib -compatibility_version 7.0 -current_version 7.0 -
install_name /Applications/GRASS/GRASS-7.0.app/Contents/MacOS/lib/
libgrass_nviz.dylib -o /Users/cmbarton/grass_dev/grass7_src/dist.i386-
apple-darwin9.4.0/lib/libgrass_nviz.7.0.svn.dylib -L/Users/cmbarton/
grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/lib -arch i386 -Os -
arch i386 -Os OBJ.i386-apple-darwin9.4.0/change_view.o OBJ.i386-
apple-darwin9.4.0/cplanes_obj.o OBJ.i386-apple-darwin9.4.0/draw.o
OBJ.i386-apple-darwin9.4.0/exag.o OBJ.i386-apple-darwin9.4.0/lights.o
OBJ.i386-apple-darwin9.4.0/map_obj.o OBJ.i386-apple-darwin9.4.0/nviz.o
OBJ.i386-apple-darwin9.4.0/position.o OBJ.i386-apple-darwin9.4.0/
render.o -lgrass_gis -lgrass_datetime -lz -lgrass_bitmap -
lgrass_linkm -lgrass_vect -lgrass_dbmibase -lgrass_gis -
lgrass_datetime -lz -lgrass_dbmiclient -lgrass_dbmibase -
lgrass_gis -lgrass_datetime -lz -lgrass_gis -lgrass_datetime -
lz -lgrass_dgl -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -
lgrass_rtree -lgrass_gis -lgrass_datetime -lz -lgrass_linkm -
lgrass_rtree -lgrass_dig2 -lgrass_gis -lgrass_datetime -lz -
lgrass_rtree -lgrass_dgl -lgrass_rtree -lgrass_linkm -
lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -
lz -lgrass_gis -lgrass_datetime -lz -lgrass_dbmibase -
lgrass_gis -lgrass_datetime -lz -L/Library/Frameworks/
GDAL.framework/Versions/1.5/unix/lib -lgdal -L/usr/X11/lib -L/usr/
X11R6/lib -lGL -L/usr/X11R6/lib -lGLU -L/Library/Frameworks/
UnixImageIO.framework/unix/lib -ltiff -lgrass_sites -
lgrass_datetime -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz
-lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -
lz -lgrass_gis -lgrass_datetime -lz -lgrass_gis -
lgrass_datetime -lz -lgrass_vect -lgrass_dbmibase -lgrass_gis -
lgrass_rtree -lgrass_g3d -lgrass_gis -lgrass_datetime -lz && \
(cd /Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-darwin9.4.0/
lib; ln -f -s libgrass_nviz.7.0.svn.dylib /Users/cmbarton/grass_dev/
grass7_src/dist.i386-apple-darwin9.4.0/lib/libgrass_nviz.dylib)
Undefined symbols:
"_GS_get_dims", referenced from:
_Nviz_set_attr in map_obj.o
"_GS_global_exag", referenced from:
_Nviz_update_ranges in change_view.o
_Nviz_change_exag in change_view.o
"_GS_get_surf_list", referenced from:
_Nviz_draw_cplane in cplanes_obj.o
_Nviz_draw_all_surf in draw.o
_Nviz_get_exag_height in exag.o
_Nviz_get_exag in exag.o
_Nviz_new_map_obj in map_obj.o
_Nviz_set_focus_map in position.o
"_GS_draw_surf", referenced from:
"_GV_load_vector", referenced from:
"_GS_draw_wire", referenced from:
"_GVL_num_vols", referenced from:
"_XOpenDisplay", referenced from:
_Nviz_create_render_window in render.o
"_GS_Set_ClientData", referenced from:
"_GV_new_vector", referenced from:
"_GS_done_draw", referenced from:
_Nviz_resize_window in change_view.o
_Nviz_draw_all_vect in draw.o
_Nviz_draw_all in draw.o
_Nviz_draw_quick in draw.o
"_XFreePixmap", referenced from:
_Nviz_destroy_render_window in render.o
"_GS_get_exag_guess", referenced from:
"_XCreatePixmap", referenced from:
"_GS_clear", referenced from:
"_GS_get_longdim", referenced from:
"_GS_set_draw", referenced from:
"_GS_unset_cplane", referenced from:
_Nviz_off_cplane in cplanes_obj.o
"_GS_set_drawres", referenced from:
"_GS_num_surfs", referenced from:
"_XFree", referenced from:
"_GS_setlight_ambient", referenced from:
_Nviz_set_light_ambient in lights.o
"_GS_draw_cplane_fence", referenced from:
"_GS_set_att_const", referenced from:
"_GV_select_surf", referenced from:
"_GV_num_vects", referenced from:
"_GS_set_viewport", referenced from:
"_GS_get_from_real", referenced from:
_Nviz_set_viewpoint_height in change_view.o
"_GS_get_from", referenced from:
_Nviz_set_viewpoint_position in change_view.o
"_GS_moveto", referenced from:
"_GS_new_surface", referenced from:
"_GVL_set_focus_center_map", referenced from:
"_GS_new_light", referenced from:
_Nviz_new_light in lights.o
"_GV_alldraw_vect", referenced from:
"_GS_set_focus_center_map", referenced from:
"_GV_set_vectmode", referenced from:
"_GS_alldraw_wire", referenced from:
"_GS_setlight_color", referenced from:
_Nviz_set_light_bright in lights.o
_Nviz_set_light_color in lights.o
"_GS_ready_draw", referenced from:
"_GS_get_zrange_nz", referenced from:
"_GS_setlight_position", referenced from:
_Nviz_set_light_position in lights.o
"_GS_unset_att", referenced from:
_Nviz_unset_attr in map_obj.o
"_GS_set_drawmode", referenced from:
"_GS_set_global_exag", referenced from:
"_GS_set_fov", referenced from:
_Nviz_set_viewpoint_persp in change_view.o
"_GS_set_att_defaults", referenced from:
_Nviz_set_attr_default in map_obj.o
"_GVL_get_vol_list", referenced from:
"_GS_set_nofocus", referenced from:
_Nviz_set_focus_state in position.o
"_GV_delete_vector", referenced from:
"_GS_set_infocus", referenced from:
"_GS_load_att_map", referenced from:
"_GS_get_zextents", referenced from:
"_GS_moveto_real", referenced from:
"_GS_init_view", referenced from:
_Nviz_init_view in position.o
"_GS_set_twist", referenced from:
_Nviz_set_viewpoint_twist in change_view.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make: *** [/Users/cmbarton/grass_dev/grass7_src/dist.i386-apple-
darwin9.4.0/lib/libgrass_nviz.7.0.svn.dylib] Error 1
