[GRASS-dev] Charset in d.vect
massimo costantini massimo.costantini at gmail.com
Tue Jul 15 02:22:40 EDT 2008
I need to set a charset ISO-8859-16 for Polish chars in my grass
application, but in command d.vect is not possible to set a charset
different from the standard (UTF-8). I've tried to use d.font.freetype
but
it only work if i don't set font option in d.vect
Thanks for your help
Massimo Costantini
