[GRASS-dev] trying to compile wxPython NVIZ
Glynn Clements
glynn at gclements.plus.com
Wed Jul 16 12:30:29 EDT 2008
Michael Barton wrote:
> > So you can debug it with e.g.:
> > gdb $GISBASE/etc/nviz2.2/nviz
> > run -f /path/to/etc/nviz2.2/scripts/nviz2.2_script
> > I wonder if this might be an issue with Tcl/Tk 8.5; Togl depends quite
> > heavily upon Tcl/Tk internals, so it's likely to be quite
> > version-sensitive.
> I tried this but I think I got ambiguous results. I tried to run this
> from the command line and maybe didn't get it right in this format.
> Anyway, here is the result.
> (gdb) run -f /path/to/etc/nviz2.2/scripts/nviz2.2_script elev=elevation.dem
This was not meant to be taken literally.
