[GRASS-dev] trying to compile wxPython NVIZ
Michael Barton
michael.barton at asu.edu
Thu Jul 17 02:37:13 EDT 2008
Would it work with 2.0?
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On Jul 16, 2008, at 11:35 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> Here is a bit of followup on Mac Aqua TclTk. I perused the TOGL site.
>> Here is what it says for Mac for TOGL 2.0
>> Mac OS X usage
>> These special instructions are for building the Aqua version of Togl.
>> Mac OS X needs tkMacOSXInt.h and other internal Tk header files.
>> Unfortunately, the Tcl and Tk frameworks that Apple distributes are
>> missing the internal headers. So you need a Tcl/Tk source
>> distribution
>> in addition to the Togl distribution (or copy over the various
>> include
>> files). You would probably want a newer version of Tcl and Tk anyway
>> because each minor revision of 8.4 has many Aqua bug fixes.
>> Here's one way to build Tcl, Tk, and Togl on Mac OS X (assuming they
>> are all in the same directory) to install in your home directory:
>> VER=8.4.12 mkdir -p ~/bin make -C tcl$VER/macosx install PREFIX="$
>> {HOME}" INSTALL_PATH="${HOME}/Library/Frameworks" make -C tk$VER/
>> macosx install PREFIX="${HOME}" INSTALL_PATH="${HOME}/Library/
>> Frameworks" APPLICATION_INSTALL_PATH="${HOME}/Applications" cd
>> Togl2.0 ./configure --prefix="${HOME}" make install
>> I checked and these header ARE present, at least for OS X 10.5.4 and
>> TclTk 8.5. They are in the PrivateHeaders folder. So maybe it is just
>> necessary to build TOGL 2.0 against the PrivateHeaders in 8.5 for
>> this.
> Note: NVIZ uses Togl 1.7.
> Glynn Clements <glynn at gclements.plus.com>
