[GRASS-dev] Python Scripting
stefano negri
ste.negri.liste at gmail.com
Fri Jul 18 06:50:58 EDT 2008
Isn't there a SWIG? I think there is a 'swig' folder in the grass
installation and I remember reading about it on the web.
Stefano.
2008/7/18 Glynn Clements <glynn at gclements.plus.com>:
> Dan D'Alimonte wrote:
>> I'm curious if any though has been given to developing an actual GRASS
>> library for Python that goes beyond calling executables with system calls?
>> I'm thinking about a model that encapsulates the GRASS environment and
>> allows for both low-level processing like the C library, and high-level
>> use of existing modules like shell scripts.
>> I'll admit I have not given this a lot of though, but a hypothetical,
>> and quickly thought-out, example could be something like:
>> from grass import module, layer, cell, parser
>> def r_add(inLayers, outLayer):
>> for outCell in outLayer.cells:
>> sum = cell(type=outLayer.cellType)
>> for l in inLayers:
>> c = l.getCellAtSameLocation(outCell)
>> if c.value==cell.null:
>> sum.value = cell.null
>> break
>> sum.value += c.value
>> outCell.value = c.value
>> outLayer.commit()
>> if __name__ == "__main__":
>> # Set up module information here
>> # Set up and run parser
>> # Open input layers
>> # Create new layer for output
>> # call r_add()
>> # close layers
>> I don't know if this would even be feasible, but I think it would make a
>> nice addition to GRASS's Python support. If done right it would even
>> allow other python-based GRASS modules to be called-on without having to
>> make a system-call (eg. from raster_add import r_add).
> Raster processing in Python is likely to be too slow to be practical.
>> As to existing modules, what about a helper function to access then?
>> module.executeModule( name="r.stats", options={ "input":
>> "elevation.dem,slope,aspect", "fs": ",", "output": "elev.csv"},
>> flags=["q", "1", "n", "g"] )
> This idea has occurred to me. Some comments:
> Pass argument values as Python values, e.g. passing multiple values as
> lists, passing numeric types directly, etc, and have the interface
> convert them to strings. Pass the flags as a single string.
> module.execute( "r.stats",
> options = { "input": ["elevation.dem", "slope", "aspect"],
> "fs": ",",
> "output": "elev.csv" },
> flags = "q1ng" )
> Provide a lower-level function which simply generates the command to
> pass to Popen(), for cases where you want to interact with the child
> process.
> Provide an intermediate function which starts the process, returning
> an object from which you can obtain structured progress information:
> percentage complete, any messages along with their type (debug, info,
> warning), etc.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
