[GRASS-dev] GRASS resets group access rights
Maciej Sieczka
tutey at o2.pl
Sun Jul 20 13:04:42 EDT 2008
Maciej Sieczka pisze:
> Glynn Clements pisze:
>> Maciej Sieczka wrote:
>>> As you can see although 2 different users (members of the same
>>> group) edit the file, permissions were not changed. Yet in GRASS
>>> they are. Is this OK?
>> Not really. How to handle this situation will need to be resolved if
>> and when we actually decide to remove the restriction that GRASS
>> doesn't allow you to modify other users' files. Until then, the goal
>> should be to determine why that restriction isn't being honoured, and
>> how to fix it.
> For now I put 'umask 7' into my grass64 executable, which forces access
> rights I desire for files newly created by GRASS.
And, forgot to say, I apply a following patch to allow non-owners to
access mapsets, per your instructions some months ago:
--- mapset_msc.c 2008-04-05 11:47:54.000000000 +0200
+++ mapset_msc.c.patched 2008-04-05 11:56:40.000000000 +0200
@@ -108,9 +108,9 @@
#ifndef __MINGW32__
if (info.st_uid != getuid())
- return 0;
+ return 1;
if (info.st_uid != geteuid())
- return 0;
+ return 1;
#endif
return 1;
@@ -141,9 +141,9 @@
#ifndef __MINGW32__
- return 0;
+ return 1;
- return 0;
+ return 1;
#endif
return 1;
Maciek
Maciej Sieczka
www.sieczka.org
