[GRASS-dev] Python script test
    William Kyngesburye
    woklist at kyngchaos.com
    Mon Jul 21 10:12:21 EDT 2008
On Jul 21, 2008, at 4:17 AM, Glynn Clements wrote:
> Michael Barton wrote:
>> Init.sh is not updating PYTHONPATH on my Mac for some reason. I've
>> looked at the code and it seems fine. I DO have a PYTHONPATH. So I'm
>> not sure why it is not updating it. If I change it manually, by
>> simply
>> pasting your code (export PYTHONPATH="$GISBASE/etc/python:
>> $PYTHONPATH") into the GRASS prompt, PYTHONPATH IS modified
>> appropriately and r_in_aster.py works fine with the new grass.py
>> library.
> I suspect that /etc/profile resets PYTHONPATH. Init.sh creates a
> .bashrc script in the mapset directory (which, at the point that the
> session shell is started, is $HOME), and that script sources
> /etc/profile.
> That's almost certainly bogus. /etc/profile is only meant to be
> sourced by login shells, not by subshells, largely for reasons such as
> this. I have fixed this in SVN trunk.
As far as I can tell, the OSX /etc/profile only *adds* to PATH and
MANPATH, and doesn't touch python stuff.
Are you sure you added PYTHONPATH code to init.sh?  I don't see
anything that sets PYTHONPATH. (just updated SVN, checked trunk also)
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
