[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Glynn Clements
glynn at gclements.plus.com
Tue Jul 22 08:07:57 EDT 2008
Michael Barton wrote:
> After some delays, I managed to recompile GRASS 7 with CFLAGS="-arch
> i386 -g", etc so that gdb would produce useful output, and with TclTk
> 8.5 aqua for Mac. Running nviz in gdb gives the results below.
> Hopefully these are more helpful. It freezes at the last line.
> Program received signal EXC_BAD_ACCESS, Could not access memory.
> Reason: KERN_PROTECTION_FAILURE at address: 0x00000024
> 0x0001702d in Togl_CreateWindow (tkwin=0x1fdb608, parent=30857160,
> instanceData=0x758db0) at togl.c:2338
> 2338 if (!aglSetDrawable(togl->aglCtx,
The complete line is:
# if defined(TOGL_AGL)
((MacDrawable *) (window))->toplevel->grafPtr
# else
((MacDrawable *) (window))->toplevel->portPtr
# endif
togl and togl->aglCtx are known to be non-NULL (otherwise it would
have crashed before then). Can you try the following:
print ((MacDrawable *) (window))
print ((MacDrawable *) (window))->toplevel
print ((MacDrawable *) (window))->toplevel->grafPtr
