[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Tue Jul 22 23:21:10 EDT 2008
>>> This actually produced some results.
>>> (gdb) print ((struct TkWindowPrivate *) (window))
>>> $1 = (struct TkWindowPrivate *) 0x1d7c648
>>> (gdb) print ((struct TkWindowPrivate *) (window))->toplevel
>>> $2 = (struct TkWindowPrivate *) 0x28
>> Ouch.
>> Do you have more than one version of Tcl/Tk on your system? One
>> possibility is that the tkMacOSXInt.h header which Togl is using
>> doesn't match the library.
>> Another possibility is that the structure packing could be affected
>> by
>> compiler switches, so if Togl isn't compiled with the same switches
>> as
>> the Tk library, it won't be accessing the fields correctly.
>> Can you try:
>> print *((struct TkWindowPrivate *) (window))
> Oh; while you're at it, can you post your tkMacOSXInt.h header?
I've put it at <http://www.public.asu.edu/~cmbarton/files/tcltk/>
This is for aqua and (I assume) for 8.5.
Michael
