[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton
michael.barton at asu.edu
Wed Jul 23 14:55:31 EDT 2008
On Jul 23, 2008, at 10:52 AM, William Kyngesburye wrote:
>>> Ideally, I think GRASS needs to detect a framework TclTk Aqua
>>> and use -framework Tcl -framework Tk instead of -ltcl -ltk to link
>>> tcltk, then the symlinks and -L flag would not be necessary.
>> Presumably this would be handled similarly to OpenGL, which already
>> has suitable configure checks.
> Hmm, it IS related. Though it's a little more complicated. OSX
> 10.4+ has a true TclTk 8.4 Aqua, but 10.3- only appears to be, but
> is really X11 (and it's the old v8.3). So we can't make any
> assumptions about the header locations.
> To make it simple for the user, tests for /Library/Frameworks/
> Tcl.framework then /System/Library/Frameworks/Tcl.framework[/
> Versions/8.4] would be needed to get the appropriate -I flags. The
> framework flags are simple because no path is needed - the linker
> looks first in /Library/Frameworks, then /System/Library/frameworks,
> so a user 8.5 would override the system's.
> Disabling/uninstalling /Library/Frameworks is simple, if a user
> wanted to build GRASS for the system framework.
Something else to keep in mind. The header I posted is needed by Togl
I think. But I also think that it is 8.5 only.
Michael
