[GRASS-dev] debugging nviz with TclTk 8.5 aqua
Michael Barton michael.barton at asu.edu
Wed Jul 23 17:15:02 EDT 2008
On Jul 23, 2008, at 1:48 PM, Glynn Clements wrote:
> Michael Barton wrote:
>> Something else to keep in mind. The header I posted is needed by Togl
>> I think. But I also think that it is 8.5 only.
> Do you mean that the packages for earlier versions don't include
> tkMacOSXInt.h? Togl definitely requires that header, so if it's only
> available with 8.5, then your only choice is 8.5.
I misspoke. At least on my office computer, tkMacOSXInt.h is available
for both 8.4 and 8.5.
> Which means that you have to link against 8.5.
> I'm not sure how OSX handles shared library versions.
> On Linux, a library named e.g. libtk.so will normally be a symlink to
> the actual library, which will include the version number. The linker
> embeds the versioned library name in the executable, and that is used
> for locating the library at run time. The unversioned symlink is only
> needed at compile time (and many distributions keep the symlink in the
> -devel package, along with the headers).
There is a lot of that on the Mac too. In the frameworks structure,
there is a "current" folder, which is a symlink to one of (often)
several versions of a package.
> The end result is that you can have multiple versions of a library
> installed, and control which version is used at compile time (without
> affecting the loading of libraries at run time) by changing the
> unversioned symlink.
> If OSX is similar, then you may just be able to delete the symlinks
> for the older versions.
> Alternatively, you could try changing the linking command in
> visualization/nviz/src/Makefile, moving XTRA_LDFLAGS (which will
> contain the --with-tcltk-libs= directory) to the beginning of the
> command, so that it takes precedence over other directories (where the
> 8.4 libraries are presumably being found by accident).
You can either directly select the version folder you want (inside the
"Versions" folder) or change the symlink "Current" folder.
Michael
