[GRASS-dev] [GRASS GIS] #231: r.li.index in 6.3.1 svn doesn't worl
trac at osgeo.org
Thu Jul 24 09:23:51 EDT 2008
Reporter: leolami | Owner: grass-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone: 6.4.0
Component: Raster | Version: unspecified
Keywords: r.li | Platform: Linux
Cpu: Unspecified |
If i create a rigth configuration file with r.li.setup (es. moving window)
and then I use r.li.shannon commands I have this error message:
GRASS 6.3.0svn (Toscana):~ > r.li.shannon map=uso_primavera_2005
conf=navacchio output=shannon --overwrite
Segmentation fault
WARNING: Can't open header file for [ in (null)]
CHILD[pid = 3613]: unable to open mask ... continue without!!!
CHILD[pid = 3612]: unable to open mask ... continue without!!!
CHILD[pid = 3611]: unable to open mask ... continue without!!!
CHILD[pid = 3610]: unable to open mask ... continue without!!!
GRASS 6.3.0svn (Toscana):~ > WARNING: Can't open header file for [ in
(null)]
CHILD[pid = 3609]: unable to open mask ... continue without!!!
CHILD[pid = 3608]: unable to open mask ... continue without!!!
CHILD[pid = 3607]: unable to open mask ... continue without!!!
CHILD[pid = 3606]: unable to open mask ... continue without!!!
CHILD[pid = 3605]: unable to open mask ... continue without!!!
CHILD[pid = 3604]: unable to open mask ... continue without!!!
Niccolò Rigacci, with the help of Markus Neteler, has recompiled GRASS and
now it works but there is ever somethings of wrong.
Niccolo can you explain what did you do and where do you think the problem
is?
Thank you
Leonardo
Ticket URL: <http://trac.osgeo.org/grass/ticket/231>
